Alex
Rep Power: 6 ![]() |
In materal database settings,for example:real-gas-Soave-Redlich-Kwong, real-gas-peng-Robinson etc.
Regards! |
These are model to model density of real gases. In reality, every gas is a real gas, i.e., their density is defined by some function of temperature and pressure. Ideal case is governed by Ideal-Gas law and most of the gases do follow this law at low enough pressure and high temperature. But there are certain phenomena that exist because gases are not ideal, such as, isenthalpic process that change the temperature of the gas during expansion in refrigerator evaporators.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
Alex
Thank you very much,regards!
density, material database |
CFD Volume change via density to obtain temp profile (gas phase) | ayaanin | Main CFD Forum | 0 | January 26, 2016 11:22 |
Density and compressiblity | Mohsin | FLUENT | 7 | June 7, 2015 22:23 |
A problem about density in liquid air definition | alloveyou | CFX | 2 | June 14, 2012 14:20 |
Mixing Plane + Ideal Gas Density (Compressible) = Tragedy | kanduri | FLUENT | 1 | June 25, 2011 17:24 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
