CFDpost exporting value
Like Tree2Likes
  • 2 Post By vinerm
Old   May 7, 2020, 15:14
Default CFDpost exporting value
Hüseyin Can Sülük
HuseyinCan is on a distinguished road
Hello guys i have done a simulation but i have some problem in cfd post i want to get torque values wrt time steps.However only i can get is torque value for one times step how can i get this data
HuseyinCan is offline   Reply With Quote
Old   May 8, 2020, 05:35
Default Torque
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
To do that, first you need to ensure that all the time data is available if you go to Time Selector in CFDPost. Then, define an expression, which could just be Torque()@location and Insert a Chart. Select Transient option under the chart and select the expression; you can directly type the expression here as well. It will plot a chart of torque vs. time. Then, you can click on Export within the Chart to export it as an external text file, if you want.
HuseyinCan and Yagu94 like this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   May 8, 2020, 11:13
Hüseyin Can Sülük
Thank you for your reply Vinerm it worked
LES data exporting & post-processing sskp STAR-CCM+ 2 April 16, 2020 04:30
Issue exporting su2 format from gmsh Gaetano03 SU2 6 September 21, 2018 11:18
exporting data from Fluent in batch mode without exporting entire design point nnvoro FLUENT 5 May 6, 2013 01:51
Exporting Outlet Conditions to Inlet viggi90 CFX 9 March 21, 2012 16:50
Star-CD4 can not read the boundaries exporting by an old version hamoudi CFX 0 May 26, 2009 12:35
