How to import Chemkin species transport file to Ansys FLUENT? |
May 13, 2020, 05:37 |
Syahirah Jaafar
Rep Power: 6 |
Hello there, I am a new Ansys FLUENT and Chemkin user and I am needed to perform a Hydrogen and Methane flame combustion simulation for my project. The problem I have faced is that once I tried to import the chemkin files for the species transport, the Fluent software just closes and return to Workbench without showing any error. How do I transport the chemkin files?
Thank you for your assistance and stay safe. P.s: I saw from other posts that it could be due to the chemkin file type (which should be in .db format), if so how do convert my .txt files to .db? The Chemkin reaction mechanism files has been attached in this post. |
May 13, 2020, 08:48 |
Mechanism
The file extension does not matter. Open Fluent standalone, i.e., outside WB, and then try to import mechanism file along with thermodynamic database. It should report some error.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
May 14, 2020, 13:27 |
Syahirah Jaafar
Rep Power: 6 |
I managed to open the file by using Fluent independently, thank you and appreciate your help.
fluent |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 14:30 |
[Other] Tabulated thermophysicalProperties library | chriss85 | OpenFOAM Community Contributions | 62 | October 2, 2022 03:50 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
