Two different periodic domains in Fluent
Like Tree1Likes
  • 1 Post By vinerm
Old   May 29, 2020, 10:54
Default Two different periodic domains in Fluent
Sai Guruprasad Jakkala
saiguruprasad is on a distinguished road
Hey,
I am trying to do Conjugate heat transfer using ANSYS Fluent.
I have a solid plate with fins on it. I have a solid-fluid-solid-fluid-solid region.
I have no inlet or outlet and have periodic boundary conditions in the streamwise and transverse directions (like DNS simulations). The temperature in the first fluid region is 875 K and the second is 675 K, but I am unable to specify this. There is only one periodic conditions option in Fluent, which sets the conditions (mass flow rate or pressure drop, and temperature of the fluid for the periodic domains).
I would like to define two different periodic conditions (different mass flow rates and temperatures). Is it possible? If it is possible, I would like to know how to do it.
saiguruprasad is offline   Reply With Quote
Old   May 29, 2020, 11:32
Default Periodic Regions
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Are these periodic regions separated by a wall? Could you share a snapshot or schematic of the domain?
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   May 29, 2020, 12:14
Yes. The periodic domains are separated by a solid region. I have attached an image of the domain.
Old   May 29, 2020, 12:35
Default Periodicity
vinerm's Avatar
Vinerm
I am afraid that's not doable, not with standard options.
Regards,
Vinerm
Old   May 29, 2020, 12:36
Is it possible to do this using some UDF or any other way?
Old   May 29, 2020, 12:40
Default Udf
vinerm's Avatar
Vinerm
Yes, you can use UDF to do this. You have to connect profiles of the boundaries that are supposed to be periodic.
Regards,
Vinerm
Old   May 29, 2020, 13:41
Can you provide some more details.
I don't actually want to connect the two fluid domains. The top fluid domain is a periodic domain and the bottom fluid domain is another periodic domain. I can create them in fluent by creating interfaces.
I would like to know how to specify different flow rates in top and bottom fluid domains and different temperatures also.
Old   May 29, 2020, 14:53
Default Periodic Domains
vinerm's Avatar
Vinerm
You can make one of the domains periodic and use periodic conditions for that domain. You can create periodic domains directly without interface provided the mesh on both periodic boundaries is same within a certain tolerance.
For the other domain, you have to write a UDF.
Regards,
Vinerm
Old   May 29, 2020, 16:24
Can you provide some tips on writing UDF for periodic domains?
I am using non-conformal periodic boundary conditions. I would like to know if it possible to write UDF for non-conformal periodic boundary.
Old   May 30, 2020, 07:46
vinerm's Avatar
Vinerm
Conformal or non-conformal don't matter much, except that you will have to do interpolation in case of non-conformal. For conformal, you can do 1-to-1 mapping. Since periodic condition is nothing more than implementation of same values of field-variables at both periodic boundaries, following algorithm could work
1. Use DEFINE_ADJUST to extract values for all fields, such as, velocity components, turbulence quantities, non-dimensional temperature, etc. at one of the boundaries. This boundary could, preferably, be set as pressure outlet.
2. Use DEFINE_PROFILE at the other boundary to apply these profiles. Since the boundaries have non-conformal mesh, you will have to interpolate the field data before applying. You will need as many DEFINE_PROFILE functions as many field variables you want to apply the condition for.
If you are comfortable with UDFs, then you can use Profile structure of Fluent to do the same. It's more sophisticated and you will not need interpolation; Fluent will do interpolation on its own.
Jjoyk likes this.
Regards,
Vinerm
Old   December 3, 2020, 03:07
Wei Xiong
Weixigggg is on a distinguished road
I've been using "system coupling" recently to try to solve this problem. However, "system coupling" cannot establish connection between two Fluent
Weixigggg is offline   Reply With Quote
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 30 December 12, 2017 05:35
Fluent Periodic flow error debashis OpenFOAM Running, Solving & CFD 2 May 24, 2017 06:24
Solid and Fluid Domains in Fluent pvtschultz FLUENT 0 December 18, 2014 09:06
[ICEM] Use Several Hexa Domains in Ansys Fluent gerardosrez ANSYS Meshing & Geometry 0 October 17, 2014 09:35
[ICEM] Interface separating 2 Domains in ICEM for Fluent antornado ANSYS Meshing & Geometry 0 January 23, 2014 22:37
