Newer fluent versions - problem with postprocessing |
May 31, 2020, 09:22 |
Marcin
Rep Power: 9 |
Hello everyone,
I was always using 17.2 version of fluent and now Im switching to newer versions, as from 2019 and 2020. Now I got two problems that was not present in 17.2: 1) The xy plane is displayed in the Fluent graphical interface, which is unconvenient when I want to save a picture - it obstures the body surfaces that Im interested 2) The journal reading in Calculation activities does not work properly, for example I got commands done in the every timestep: q q file r-j journal.txt q q q, and Fluent says: Error: Journal file "q" not found. Error Object: #f Which is very problematic when some automation is done Please give me some idea on how to hide this xy plane and how to edit the commands in Calc. Activities Kind regards Destroy |
June 2, 2020, 05:58 |
Ground Plane and Journal
1. You can disable the ground plane using File > Preferences > Graphics > Ground Plane Grid
2. That's the problem with the journal. Even if you use that journal in Fluent 6.3, the error would be same. Remove all q.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
Stefan problem using fluent | Isaacibp1401 | Fluent Multiphase | 2 | June 7, 2021 05:49 |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 04:37 |
Problem with Volumetric Reactions in Fluent | Kashif Rashid | Fluent UDF and Scheme Programming | 2 | December 28, 2017 00:36 |
fluent parallel problem in win7 x64 system | dunga82 | FLUENT | 8 | April 19, 2012 20:23 |
fluent convergence problem | josip76 | FLUENT | 0 | May 26, 2011 20:08 |
