Fluent udf give zero instead of coordinate location
Like Tree1Likes
  • 1 Post By vinerm
Old   June 2, 2020, 03:35
Default Fluent udf give zero instead of coordinate location
cfdnewb123 is on a distinguished road
I am working on DEFINE_TURBULENT_PROFILE. However, x[ND_ND] doesn't seems to work for me as it gives me zero. When I try monitoring its output (e.g. Message("x=%g and y=%g \n", x[0], x[1]) on Fluent's console, I saw this instead - x=0 and y=0.
Basically it just keeps showing me zero. Even when I try "Message("x=%g and y=%g \n", x[0], 2);" but it shows 0 instead of 2! When I try outputting other output like S, the message doesn't show 0.
Is x[ND_ND] ONLY for the "DEFINE_PROFILE" udf? Does it works for others like mine case?
cfdnewb123 is offline   Reply With Quote
Old   June 2, 2020, 04:21
Default Typecast
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
That's because you are expecting the compiler to do the typecasting for you. 2 is an integer and you are trying to print it as float or double. Use 2. or 2.0. Furthermore, %g is not a good format specifier for such numbers, use %f or %lf.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   June 2, 2020, 08:28
Thanks for the reply. My issue is I am trying to define eddy viscosity as a function of position. I use xx=x[0] and y=x[0] but the position keep giving me 0. Because of this, my eddy viscosity is no longer a function of position as the position is constantly 0!
E.g. I try
if (y>0.1) {S=2}
else {S=1}.
My solver keeps giving y=0 and thus the above sample if-else loop is meaningless as S is constantly 2.
Old   June 2, 2020, 08:30
Default The Code
vinerm's Avatar
Vinerm
Most likely the reason is as I mentioned earlier, use of int values in place of real. If it is something other than that, I'd suggest you to copy whole code here for faster debugging.
Regards,
Vinerm
Old   June 2, 2020, 08:47
The code works fine other than the if-else which does not switch as x & y are constantly equals to 0.
DEFINE_TURBULENT_VISCOSITY(test_mu_t,c,t)
real x[ND_ND];
real xx,y;
real mu_t;
real rho = C_R(c,t);
real k = C_K(c,t);
real d = C_D(c,t);
real Omega, alpha;
real dudx = C_DUDX(c,t);
real dudy = C_DUDY(c,t);
real dvdx = C_DVDX(c,t);
real dvdy = C_DVDY(c,t);
xx = x[0];
y = x[1];
alpha = 1+y;
if (xx >= -0.1 && xx <= 0){
Omega = sqrt(abs(2*((0.5*(dudy-dvdx)-(1.76656/(alpha)))*(0.5*(dvdx-dudy)+(1.76656/(alpha)))*2))); //+ (d/k)*Cw*epsilon_xy*(31.76656/(alpha*R));
else {
Omega = sqrt(abs(0.5*((dudy-dvdx)*(dvdx-dudy) + (dvdx-dudy)*(dudy-dvdx))));
Message("Check to see if loop reaches here. x=%g.\n",xx);
mu_t = Cmu*rho*k*5/(SQR(Omega));
return mu_t;
Old   June 2, 2020, 08:51
Default Centroid
vinerm's Avatar
Vinerm
xx and y are 0 because x itself is 0. You have to use C_CENTROID(x, c, t) before setting xx = x[0] and y = x[1].
cfdnewb123 likes this.
Regards,
Vinerm
Old   June 2, 2020, 08:55
May i know how to use C_CENTROID(x, c, t)?
Do I just include C_CENTROID(x, c, t)? According to this site (https://www.afs.enea.it/project/nept...ec-define-init),
real x[ND_ND];
real xx,y;
real mu_t;
real k = C_K(c,t);
real d = C_D(c,t);
real Omega, alpha;
C_CENTROID(x, c, t)
xx = x[0];
y = x[1];
alpha = 1+y;
else {
Message("Check to see if it reaches here. x=%g.\n",xx);
return mu_t;
Old   June 2, 2020, 08:59
Thanks so much! It works!
Old   June 2, 2020, 09:15
Default Good
vinerm's Avatar
Vinerm
Nice to know.
Regards,
Vinerm
ansys, fluent, udf
Passing udf value to fluent durg Fluent UDF and Scheme Programming 2 February 11, 2019 12:55
Fluent do not use my velocity field(by UDF) to solve energy equation tangleiplus Fluent UDF and Scheme Programming 6 January 21, 2019 21:28
Fluent Boundary Condition with UDF amitjoshi FLUENT 0 November 16, 2018 02:21
Integrating data from UDF to Fluent say2017 FLUENT 0 October 20, 2017 13:50
Beginner help, coordinate udf with output file nb92 Fluent UDF and Scheme Programming 0 March 20, 2014 04:16
