Question on Convective augmentation factor (UDF) |
Rep Power: 6 ![]() |
Hi there,
I’m working with the convective augmentation factor (section 6.3.14.3.6. Augmented Heat Transfer in Ansys User’s guide). Following the instruction, this factor should be assigned using text command. 1.png In fact, I noticed that it can be created as a udf profile. I wonder which UDF function should I use? I tried to create the following one (just a test case, to see if it can be compiled), but not success. DEFINE_PROFILE(flux_heat_Augfac, t, i) { face_t f; begin_f_loop(f, t) { F_PROFILE(f, t, i) = 20.; } end_f_loop(f, t) } Am I using the wrong function ? (I didn't find any example in the UDF user's guide.) |
UDF is not required if you want to apply a single value or a fixed profile. However, you can use a UDF if the value of augmentation factor changes with the solved field.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
Well, in my case, I'm pretty sure it is not a fixed value or a constant. I have to use UDF. Could you please show me an example of UDF on Convective augmentation factor? Thanks a lot.
You can use any general DEFINE_PROFILE UDF, even the one you shared in your post.
cht, heat transfer, udf |
Question Re Engineering Data Source | imnull | ANSYS | 0 | March 5, 2012 13:51 |
Convective flux exceed limit warning | quemmo | FLOW-3D | 1 | October 5, 2011 11:57 |
internal field question - PitzDaily Case | atareen64 | OpenFOAM Running, Solving & CFD | 2 | January 26, 2011 15:26 |
Question about Table applicaiton. | universez | OpenFOAM Running, Solving & CFD | 0 | January 12, 2010 20:31 |
the calculation of convective flux | Hai-Wen Ge | Main CFD Forum | 14 | April 23, 2001 06:34 |
