June 7, 2020, 10:29 |
2D NACA 0012 Steady State Validation
Rep Power: 6 |
I'm trying to validate my mesh in steady state by comparing the values of cl and cd with xfoil prediction from http://airfoiltools.com/polar/detail...0012-il-100000
At AOA 2 degree, xfoil prediction has values of cl and cd at 0.3737 and 0.01444 respectively. However, from the simulation results, I got cl = 0.106 and cd = 0.02. Chord length = 0.156 m Inlet velocity = 10 m/s Density = 1.225 kg/m3 Viscosity = 1.7894e-5 kg/m/s Pressure-based SST k-omega model Velocity inlet and pressure outlet Periodic matching at the interface PISO scheme with second order upwind for momentum, turbulent ke and specific dissipation rate y+ value ranging from 0 to 1.3 I've tried different settings (scheme, low Re correction) to see the differences but it didn't help. I'm not sure what is the cause, maybe I did some mistakes that I'm not aware of. Hope someone could help me out please. |
June 7, 2020, 13:05 |
duri
The Xfoil transition occurs near TE. It means the solution corresponds to laminar. Force LE transition in Xfoil and compare.
June 11, 2020, 04:58 |
#3 | |
mCiFlDk
Rep Power: 6 |
I can see two points where the problem can be:
I hope it helped, Regards. |
NACA 0012 low speed validation problem | 35matt215 | CFX | 3 | March 4, 2019 18:44 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 05:37 |
Validation of NACA 0012 against Nasa published; | shereez234 | FLUENT | 2 | November 25, 2017 11:27 |
XFlow Naca 0012 Validation | Mythorpios | Main CFD Forum | 1 | June 27, 2016 13:05 |
