Boundary Condition Setting up
Old   June 12, 2020, 08:17
Unhappy Boundary Condition Setting up
Mariposa Bon
mariposa is on a distinguished road
I recently want to simulation an axial fan that work like wind tunnel so the input pressure is negative and the output pressure is positif. I also want to input mass flow 32.5 kg/s.
But the problem is, i've trying to make the boundary inlet is mass flow but its still goes false, while the result in input and output get exchange.
Honestly i still confuse how to use boundary condition, like pressure inlet, velocity inlet, massflow, exhaust fan, intake van and also function each of them.
I really need your help guys, please help me.
Thank you
mariposa is offline   Reply With Quote
Old   June 14, 2020, 11:50
mCiFlDk's Avatar
mCiFlDk
mCiFlDk is on a distinguished road
Thank you
Hi mariposa,
Could you share with us a screenshot of the whole bunch of boundary conditions?
Regards.
mCiFlDk is offline   Reply With Quote
Old   June 15, 2020, 07:06
Default Boundary Condition
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Thank you
If the flow is incompressible, then it won't matter much whether the pressure is positive or negative. The only difference you will observe is in the flow profile at the boundaries. Just apply a mass flow outlet at the outlet, since that's what fan would be doing; sucking the air. And apply pressure inlet with total pressure of 0 Pa at the inlet. However, the situation would be entirely different if the flow is compressible.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   June 15, 2020, 13:04
Mariposa Bon
Hi mariposa,
Well, firstly i just drew a boundary only in (a) and in (d) but my lecture said that i've to add some new selection name in (b) and (c), so in my BC the (a) i set to mass flow inlet that has 32 kg/s and the pressure is -4336 Pa and in the (d) i set an outflow because i want to know about the outlet pressure.
but in (C) and (d) i get confused because the BC show just like this option
thats why i get confused what should i do with that boundary condition, while in my real data the (a) is -4336 Pa and in (d) is 1236 Pa. thats why i need ur help. thank you
Last edited by mariposa; June 15, 2020 at 13:13. Reason: now the picture was showed
Old   June 15, 2020, 13:11
Mariposa Bon
unfortunely i forgot to mention that my fluid is a compressible air that have density is 0.77 kg/m3
Old   June 15, 2020, 13:13
Mariposa Bon
Originally Posted by mCiFlDk View Post
Hi mariposa,
Regards.
Attachment 78372
Attachment 78373
Old   June 15, 2020, 16:18
Default Boundary Conditions
vinerm's Avatar
Vinerm
You cannot apply any condition at the interior boundaries, nor are those required. Check with your lecturer why those are required; possibly for data extraction. Or if you wish to rotate the rotor. Then, it has to be interface and you have to slit the boundary or generate non-conformal mesh at the meshing stage. So, check before you proceed.
If the flow is compressible, then you have to set operating pressure as 0 and use only positive pressure values at the boundaries. Do not use negative pressure values. Use mass flow at the outlet and pressure inlet at the inlet. Do NOT use outflow.
Regards,
Vinerm
Old   June 15, 2020, 20:42
Mariposa Bon
Thanks i did like what u said, and for the pressure its correct such like i want. But when i saw the vector, it show that the flow is from Output to Input. So i change the direction vector in mass flow Z=1 (direction from input to Output) but the pressure get decrease. Am i should to increase the pressure inlet ? Thanks
boundaries condition, fluent
3D Windturbine simulation in SU2 k.vimalakanthan SU2 15 October 12, 2023 05:53
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 08:44
Time dependant pressure boundary condition yosuke1984 OpenFOAM Verification & Validation 3 May 6, 2015 06:16
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
vorticity boundary condition bearcharge Main CFD Forum 0 May 14, 2010 11:32
