inflow velocity distribution is given by the Poiseuille flow
Old   June 12, 2020, 23:53
Default inflow velocity distribution is given by the Poiseuille flow
Weiqiang Liu
Weiqiang Liu is on a distinguished road
Hi all,
I am trying to reproduce results in literature. For inlet velocity boundary condition setting, the author says "The inflow velocity distribution is given by the poiseuille flow"
I know poiseuille flow is a parabolic velocity distribution from central to wall. I am wondering how can I set the parameters of this parabolic distribution if I know the central velocity of inflow?
Best regards
Weiqiang
Weiqiang Liu is offline   Reply With Quote
Old   June 14, 2020, 12:05
mCiFlDk's Avatar
mCiFlDk
mCiFlDk is on a distinguished road
Originally Posted by Weiqiang Liu View Post
Hi all,
Best regards
Weiqiang
Hi weiqiang,
To make that, you've to use a User Defined Function, more specifically a DEFINE_PROFILE one. Luckily, ANSYS has a very similar function in its manual to imitate this problem you're trying to simulate.
vprofile.c
UDF for specifying steady-state velocity profile boundary condition
#include "udf.h"
DEFINE_PROFILE(inlet_x_velocity, thread, position)
  real x[ND_ND]; /* this will hold the position vector */
  real y, h;
  face_t f;
  h = 0.016; /* inlet height in m */
  begin_f_loop(f,thread)
    F_CENTROID(x, f, thread);
    y = 2.*(x[1]-0.5*h)/h; /* non-dimensional y coordinate */
    F_PROFILE(f, thread, position) = 0.1*(1.0-y*y);
  end_f_loop(f, thread)
Code got from: https://www.afs.enea.it/project/nept...df/node243.htm
If you look a bit deeper in the manual, this will not be very complicated since the function is that and you only have to modify the parameters for your specific case.
Regards.
mCiFlDk is offline   Reply With Quote
inlet boundary, poiseuille flow
velocity and cell coordinates on Threshold plane- Inflow Plane of virtual Disk surajp92 STAR-CCM+ 2 June 21, 2017 09:48
3D Velocity profile for turbulent flow Kirill Fluent UDF and Scheme Programming 3 July 17, 2014 08:42
Steady pipe flow mean velocity higher than inlet velocity anita OpenFOAM Running, Solving & CFD 7 September 25, 2012 05:35
Outlet BC for disturbed Poiseuille flow murx CFX 10 February 22, 2012 13:55
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
