Bias factor on a radius
Like Tree1Likes
  • 1 Post By mCiFlDk
Old   June 11, 2020, 09:11
Default Bias factor on a radius
Francesco
franc1 is on a distinguished road
Hi everybody,
I'm performing a thermal analysis over a 2D disk surface.
My aim is to refine the mesh along the radius of the disk in a specific way and bias factor is what i must use to do this task.
The problem is that i cannot draw a line along the radius on the mesh in which i have to apply the bias factor tho. Any suggestion on how to do it?
I think that the problem is quite trivial, but i just can't find a solution
Thank you in advance.
franc1 is offline   Reply With Quote
Old   June 12, 2020, 09:18
Francesco
Nobody can help?
Old   June 14, 2020, 11:54
mCiFlDk's Avatar
mCiFlDk
mCiFlDk is on a distinguished road
Originally Posted by franc1 View Post
Hi everybody,
Hi franc1,
I can't think in other way to do what you want to. I would use Spaceclaim or Design Modeler to divide my geometry into two parts with a simple sketched line, and there you can use the bias factor.
Regards.
franc1 likes this.
mCiFlDk is offline   Reply With Quote
Old   June 18, 2020, 15:33
Francesco
Thank you for reply mCiFlDk
[TurboGrid] Wind turbine: problem with the hub radius MrDaimon ANSYS Meshing & Geometry 0 March 12, 2015 08:12
Gas flow through a channel with sudden radius expansion Blooper SU2 4 June 5, 2014 15:40
Sampling along a radius djh2 OpenFOAM Post-Processing 2 March 25, 2014 10:26
Meshing of a sharp edge orifice with a radius Moose1231 STAR-CD 3 December 6, 2011 15:32
How Bubble Radius is Found in Cavitation Chris Siemens 7 June 22, 2004 12:43
