Number of mesh elements as a output parameter of Fluent? |
July 1, 2020, 04:31 |
Rep Power: 5 |
Hi!
I am doing a grid independence study. I am using workbench and the problem is that I used ansys meshing to do tetrahedron grid and then I changed it to polyhedra mesh in Fluent. Because of that I can't use mesh statics of ansys meshing as output parameters because these are not the exact numbers. Is there a way to make number of elements to output parameter of Fluent? |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 07:56 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
SigFpe when running ANY application in parallel | Pj. | OpenFOAM Running, Solving & CFD | 3 | April 23, 2015 14:53 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
