mixture can not be ignited when parallel mode is used |
August 2, 2020, 21:32 |
Weiqiang Liu
Rep Power: 9 |
I am simulating a propane catalytic combustion with fluent. The golobal one-step gas phase and surface reaction rate are defined with DEFINE_VR_RATE and DEFINE_SR_RATE macros. I found an interesting thing that is when I use serial mode, then mixture can be ignited. However, when I use parallel model of fluent, mixture can not be ignited. Mixture temperature just drops all the way down to room temperature when iteration get started. I am wondering why would this happen? Do I need to parallelize my UDF code? Best regards Weiqiang |
gas phase rate, ignition, parallel mode, serial mode, surface rate |
Unsteady Inlet Velocity UDF in Parallel Batch Mode | vtyler | Fluent UDF and Scheme Programming | 4 | April 1, 2020 05:44 |
Source is incomplete in parallel mode | sakura006 | FLUENT | 1 | June 18, 2018 10:29 |
problem with compiling boundary condition udf in parallel mode | chem engineer | Fluent UDF and Scheme Programming | 11 | June 29, 2015 06:23 |
Does anyone have any experience with cfd-fastran (2008.2) on parallel mode? | CFD_1977 | Main CFD Forum | 0 | March 30, 2014 07:01 |
How to run icoFsiFoam in parallel mode? | AsDF | OpenFOAM Running, Solving & CFD | 2 | February 21, 2014 07:56 |
