Heat transfer between two closed cavities with natural convection
Old   October 28, 2014, 05:39
Question Heat transfer between two closed cavities with natural convection
Cezary
Czarulla is on a distinguished road
I am modelling a 2D axisymmetric heat transfer between two closed cavities. One is filled with air, another with helium. Heat source is placed at the axis. BC is a constant temperature at the wall of the outer domain - air. Heat is being transferred through the natural convection (no pressure BC, no inlet or outlet). I am using Fluent software. My question is: Is it possible to determine different operating conditions for those domains, as Fluent requires operating density and pressure for natural convection calculations. Helium and air are under different pressure and of course have different densities. Had anyone solve such case?
I am working also on 3D version of this problem, however calculations are quite time consuming, so I use 2D for preliminary settings.
In the picture green is helium, blue is air.
I would appreciate any possible help with this case.
Does using 0 for operating density solve the problem? Is it obligatory for solver to use operating density for natural convection?
Regards,
Czarulla
Czarulla is offline   Reply With Quote
Old   November 19, 2014, 07:18
Cezary
For other users, I have solved the problem. There is no possibility of setting two different operating pressure and densities. However, my fault was using incompressible ideal gas model. Now I use ideal gas model and set operating density to 0, operating pressure equal pressure in one domain. When both domains have different pressure, you need to patch appropriate pressure in both domains. Remember that ideal gas model is using pressure in cell + operating pressure for calculating density. What is more, Full Bouyancy option have to be picked. With that option you can simulate your transient with natural convection.
Old   August 5, 2020, 12:36
Himanshu
Himanshu_Shrivastava is on a distinguished road
Hello sir,
Why is the reason of setting operating density to 0 for ideal gas?
Himanshu_Shrivastava is offline   Reply With Quote
natural convection, operating conditions, operating density, operating pressure, two domains
Natural Convection heat transfer problem srinivasa FLUENT 21 November 11, 2016 06:08
Doubling heat transfer (convection calculation) ninjakid FLUENT 0 July 3, 2012 12:03
natural convection mehrdadeng CFX 10 February 25, 2011 05:25
Forced convection heat transfer in heat sink Sidy FLUENT 1 October 18, 2008 03:27
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 20:28
