ANSYS Fluent External Airfoil Flow - Non-Convergence Post-Stall
Old   August 10, 2020, 17:43
Unhappy ANSYS Fluent External Airfoil Flow - Non-Convergence Post-Stall
sbro is on a distinguished road
I'm currently simulating flow around an airfoil (different test cases with various trailing edge modifications) using ANSYS Fluent and a Coupled scheme (2nd Order) with Higher Term Relaxation and Pseudo Transient enabled.
My solution (for all test cases) converges for pre-stall Angles of Attack below 13 degrees (all residuals reduce to ~<2E-04 and steady force coefficients converge) but doesn't converge for post-stall angles (14-18 degrees).
I thought this would likely be due to transient flow features (shedding) not properly captured by the steady solver but, curiously, the solution at 20 degrees (highest angle tested) DOES converge which I don't understand(?). I would've thought if the solution converged at 20 degrees and for the lower angle sweep then the intermediate values should also...
I've tried almost every trick to try and resolve for the solution(s) that won't converge; a higher resolution mesh, switching to 1st order, adjusting under-relaxation factors and I can't get anything to work. Switching the far-side boundary conditions (wing-tip side; see below) to either a slip / no-slip wall achieves convergence but a horrendous result which isn't feasible next to experimental data. My mesh statistics could also be better but if this was the issue then I wouldn't expect convergence for any of the angles tested?
Any ideas for what I can try would be greatly appreciated and if you need any further information please don't hesitate to let me know.
I've posted my boundary conditions and a vague idea of my mesh sizing below.
- Blue (Front and WingTip-Side Face: Velocity Inlet)
- Red (Rear Face: Pressure Outlet)
- Yellow (WingRoot-Side Face: Symmetry Plane)
sbro is offline   Reply With Quote
airfoil 3d, ansys, cfd aerospace, convergence, fluent
High drag for airfoil compared to XFOIL and wind tunnel data Ry10 SU2 15 October 30, 2016 17:27
Modelling Slug Flow in ANSYS Fluent VOF. OliverMechEng2208 Fluent Multiphase 1 March 18, 2015 05:45
CGNS Compiling Diego Main CFD Forum 17 December 21, 2014 01:40
Surface Pressure Gradient at Heaving Airfoil in ANSYS Fluent saifullahkhalid FLUENT 0 November 11, 2013 04:17
How to model suction flow in an airfoil in Fluent Davy FLUENT 4 October 23, 2006 03:56
