unsymetric temperatur profil
Old   August 10, 2020, 05:50
Default unsymetric temperatur profil
Lukas
lukas' is on a distinguished road
Hello everybody,
currently I am working on my thesis for which I did some Fluent simulations. My studies focused on the temperatur-profile in an installations space. The heat-source is in the middle and the components are symmetric. In the results the temperature-profile is not 100%-symmetric.
Can anyone tell me possible reasons and maybe a source that I can cite for my thesis?
Thanks in advance!
Best wishes!
Lukas
lukas' is offline   Reply With Quote
Old   August 11, 2020, 00:59
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
how could you know, that it's not symmetric? how did you check it?
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   August 11, 2020, 02:46
Lukas
I expect that because of theoretical thoughts.
In my view there is reason why it should not be symmetric.
Old   August 11, 2020, 04:32
karachun's Avatar
karachun is on a distinguished road
lukas' You should bring to us more information - physical description, computational (fluent) description, also it will be good if you give us your thoughts why flow is unsymmetric.
At this point we are talking about "black box". For black box I can give two general assumptions.
1. Your mesh is too coarse.
2. Flow have transient nature.
karachun is offline   Reply With Quote
Old   August 11, 2020, 04:50
Lukas
There is no external flow. It is a heater with a constant temperature in the middle of an installation space. It is surrounded by cylindral components. All the components are symmetric. I used the SST-model and S2S-model for radiation.
I don't see a reason why the temperature of a part of a component should have a different temperature that the same part that is on the other side of the heater with the same distance away. We talk about ~10°C at temperatures between 20°C and 500°C. So the diffenrence is not really big. I hope this helps to understand my problem in a proper way.
What I actually want to know if the difference might come from the meshing or the solution algorithm,... I checked mesh quality - it should not be the problem.
Sorry if my information was not complete yet but I'm a beginner in CFD... I hope this helps now.
Thanks for your answers!
Old   August 12, 2020, 08:40
Alexander
from my experience, convection problems sometimes shows this asymmetric solutions.
you may try:
1. use other turbulent model
2. decrease residual levels
3. increase order of spatial discretization (in solution methods)
4. initialize the flow symmetrically using PATCH tool (which may be tricky), easy approach is to initialize case with small flow velocity value from bottom to top, and calculate
5. ofc mesh could be a problem, try to make new mesh, most likely you will get new result
6. you may switch from steady-state to transient (but it is computationally expensive)
best regards
Import Profil from CFX-post plan to CFX-pre Inlet YuguiYo CFX 5 June 17, 2016 04:17
Probleme to interpret 3D temperature profil UDF christophe06 Fluent UDF and Scheme Programming 4 February 20, 2012 08:06
transient BC profil at INLET Zigainer CFX 6 December 4, 2011 04:42
Boundary Conditions: Non constant flow pattern / temperature profil Janshi FloEFD, FloWorks & FloTHERM 1 September 1, 2010 02:56
Temperature Profil Plate UDF mannobot FLUENT 0 June 16, 2010 13:06
