Shock tube species transport divergence
Old   August 13, 2020, 08:07
Default Shock tube species transport divergence
Tomás Costa
tomhcosta is on a distinguished road
I'm modeling a 2D shock tube, in fluent, as a rectangle (1meter long by 6cm diameter) with 2 separated sections, a high-pressure one called driver and a low pressure one called driven. Im using density-based solver with transient analysis, inviscid with energy eq. and species transport with hydrogen-ar mixture with both as ideal gas. I set the operating pressure inside to 0 pa. After this i Initialize with 10 bar in the driver section and 1 bar in the driven section and value 1 of hydrogen for the driver section. I run the calculations for 50 time steps of 20 iterations each with a time step of 7e-06s and i do all of this with 4 solver processes and double precision.
When I model it for 10 bar, it all goes smooth and the solution converges but when i change the driver pressure to 20bar or higher the solution diverges a lot and presents results like 0 pressure along the shock-tube. The reason i am doing this is to see the temperate and density behaviour for different pressures inside the shock-tube and then test if the length of the tube will have any effect on them.
I think this is a very simple problem but i just can't seem to get it right. If anyone can help, i would be very grateful.
tomhcosta is offline   Reply With Quote
Old   August 14, 2020, 01:21
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
did you try to decrease timestep?
you may also decrease under relaxation factors and switch to first order discretization models
if you are using not default material properties, check them again
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   August 14, 2020, 05:25
Tomás Costa
Like
best regards
Since I am modeling a shock tube, I am using density based solver so there are no urfs saddly.
I can try to reduce the time step but since it is already at 7e-6 do you think it can be reduced more? What would this do?
Haven't tried the first order discretization, will try but can you explain what this does in relation to second order?
Thank you,
Tomás
shock-tube, species-transport, transient
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 07:54
Species transport for decomposition reaction achrofi FLUENT 1 August 1, 2017 12:26
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 16:08
user defined scalar vs species transport gvj_mech FLUENT 0 March 27, 2014 14:33
Divergence problem Smaras FLUENT 13 February 21, 2013 05:03
