August 21, 2020, 15:30 |
UDF for charge density parameter
Alex
Hello, i'm trying to use UDF for charge density of inert particles. I'm using MHD module and DPM.
When using discrete phase sample on reports (particle tracks for example) i see error: Error at Node 2: get_udf_function: function charge_density_macro has wrong type: 2! = 46. It happened even with simple code like i used last time: #include "udf.h" DEFINE_DPM_PROPERTY(charge_density_macro, c, t, p, T) { real charge_density; charge_density = -1; return charge_density; } I know, error means that i'm using wrong type of udf for this parameter, but i wonder what i do wrong... P.S. If i use interpreted , here is no mistake. That erroe happenes only when i use compiled code (i need to use compiled for main code) Last edited by ofsavier; August 22, 2020 at 07:42. |
August 24, 2020, 00:26 |
Alexander
Rep Power: 34 |
I've compiled this code without any error
Are you sure you can define negative density?
best regards ****************************** press LIKE if this message was helpful |
mhd, udf |
UDF for modifying density of mixture phase during the calculating process | sola86 | Fluent UDF and Scheme Programming | 2 | May 28, 2019 09:24 |
confusion on how to write udf for density of a mixture solution in multiphase problem | Hirakjyoti | Fluent UDF and Scheme Programming | 1 | September 11, 2017 01:21 |
Density UDF Divergence | Baden | Fluent UDF and Scheme Programming | 0 | January 11, 2017 15:25 |
UDF for solid density | gghazal | Fluent UDF and Scheme Programming | 3 | November 13, 2012 03:10 |
UDF: Density Cell Gradient Vector Macros | matteo | FLUENT | 0 | December 1, 2007 12:14 |
