Unable to get positive lift for ornithopter analysis
Old   January 16, 2021, 10:20
Question Unable to get positive lift for ornithopter analysis
Nishanth is on a distinguished road
I've been trying to perform a CFD analysis of a flapping wing. Please view the attached images.
I have taken a flat rectangular wing inclined at an angle of 45d to the wingspan-axis and 15d to the fuselage-axis.
I created a cylinder around it so that the cylinder rotates and inturn the wing rotates. I created a cuboidal part that acts as a wind tunnel.
I gave a velocity of 2m/s and performed a transient CFD analysis and measured the lift after every time step.
I'm using the k-e, RNG, swirl dominated flow with scalable wall function.
The problem is I'm getting negative cl and inturn a negative lift force.
Can you please help me figure out why I'm getting a negative lift and how to make it positive?
I first created a boolean between the wing and the rotating wall and then a boolean (while preserving body) between the wind tunnel and the rotating wall.
UPDATE: The lift is positive when I do a static analysis at -15d and 60d dihedral. But as soon as a start the mesh motion the lift goes negative!
https://youtu.be/jM-M0eLhM_4
Nishanth is offline   Reply With Quote
Global stability Analysis of flow around a cylinder: All eigenvalues positive Werne Main CFD Forum 8 February 27, 2021 15:57
Unable to get positive lift for ornithopter analysis Nishanth Main CFD Forum 2 January 17, 2021 02:01
How to calculate lift, drag and lift distribution in Star CCM+? israelcasillas94 STAR-CCM+ 4 November 6, 2020 08:35
Positive Lift force for a vehicle ? mansouri FLUENT 1 January 20, 2015 07:58
unable to obtain residual and lift coefficient convergence in SU2 deeps SU2 3 December 27, 2013 01:58
