November 12, 2020, 13:18 |
Calculation of tangential velocity
kukka
Rep Power: 7 |
Hi!
I am simulating swirling flow in a pipe with y-axis coinciding the axis of the pipe. Now I wish to calculate tangential velocity and radial velocity. Probably that could be done by using custom field function. What equations shall I use to calculate the above two velocity components? Thanks and Regards |
November 13, 2020, 11:56 |
kukka
Rep Power: 7 |
I would appreciate if any reference related to this is shared.
November 18, 2020, 10:45 |
Lorenzo Galieti
Rep Power: 12 |
It's high school trigonometry with a bunch of sines and cosines, no need to post references. I wrote cylindrical coordinates on google and those are the two first results
i get https://mathworld.wolfram.com/Cylind...ordinates.html https://tutorial.math.lamar.edu/clas...calCoords.aspx Look for more and read. Again, this is simple maths, you can also derive the formulas on your own without any reading, just paper and pen |
November 18, 2020, 12:13 |
Rep Power: 8 |
I wish if I would have performed few simulations during my high-school time itself.
November 18, 2020, 14:13 |
Lorenzo Galieti
Rep Power: 12 |
I did not run CFD in high school.
What I am saying is that to calculate a tangential velocity you need the velocity magnitude and a bit of trigonometry. Really, draw a circle (which is a section of your pipe) and draw a tangential velocity vector, which means the component of velocity perpendicular to the radius and lying on the section of the pipe. |
Panel-Method, velocity calculation | mrbm | Main CFD Forum | 17 | August 5, 2022 11:03 |
Calculation of Velocity u.Gradient X | Ever Seen a Tornado? | CFX | 3 | November 14, 2015 06:01 |
Radial velocity and tangential velocity on centrifugal fan, | johnnyp | FLUENT | 2 | May 24, 2013 07:10 |
tangential velocity on a velocity inlet in 2D | bretti | FLUENT | 0 | July 3, 2007 08:42 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
