Enthalpy Value Reported under Surface Integral |
January 28, 2021, 20:39 |
CWL
Rep Power: 10 |
I am wondering if anyone knows how does Fluent compute the enthalpy values given in Surface Integral > Temperature > Enthalpy. The values that I got from fluent for a flow through CD nozzle are in the range of -50000 to 40000 J/kg. These are way off than the values given in any steam table. Why are there negative values as well? I could not figure out what is the reference value (the thermal condition that give zero enthalpy) in Fluent to try to shift the results.
Any helps appreciate. |
[Gmsh] gmshToFoam generates patches with 0 faces and 0 points | Simurgh | OpenFOAM Meshing & Mesh Conversion | 4 | August 25, 2023 07:58 |
Difference between flux reports and surface integral reports | edmondlam | FLUENT | 0 | November 14, 2017 14:23 |
[OpenFOAM] Compute Surface Flow & Integral | Victorien | ParaView | 0 | July 8, 2014 05:57 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
Surface Integral - Mass Flow Rate | Venkatesh V | FLUENT | 3 | October 10, 2008 16:18 |
