Turbulence and viscosity of non-Newtonian Fluids
Like Tree1Likes
  • 1 Post By David
Old   November 14, 2005, 08:00
Default Turbulence and viscosity of non-Newtonian Fluids
David
Hello, I use fluent and need to simulate polymer viscosity vs shear rate and the turbulence. I've try with some turbulent models but they want constant viscosity to calculate the turbulence.
Is it possible to copy the non newtonian model in a UDF and then use a turbulent model. I've never try to use UDF until now.
Thank you for advice
David
drszhang likes this.
Old   November 14, 2005, 09:17
Default Re: Turbulence and viscosity of non-Newtonian Flui
HVN
To use turbulence with non-newtonian fluid, you need to activate the turbulence model through the command line not through the GUI.
So to resume, you doesns't need to use UDF for your problem.
Old   November 16, 2005, 09:26
David
I wrote
define/models/viscous/turbulence-expert/turb-non-newtonian?
but the command is not valide. I received this message "invalid command".
Thanks
Old   November 16, 2005, 09:52
Wael
What version of Fluent do you have? in 6.0.12 the command is not available.
Old   November 17, 2005, 04:08
David
The version is Fluent 6.2.16.
Is it possible to check if I have all the libraries to use the turbulence with the viscosity of non newtonian fluids.
Old   November 17, 2005, 04:39
Wael
Hi David, First select the standard k-e model, then use TUI and write define\model\viscous\turbulent expert\ Then you can select
turb-non-newtonian? Enable turbulence for Non-Newtonian fluids.
non-newtonian-modification? Enable Non-Newtonian modification for Lam-Bremhorst model.
Hope that can help - Wael
Old   November 17, 2005, 11:23
David
Thank you a lot.
I use it with non newtonian power law.
Old   November 29, 2005, 07:09
Zahra
I wanted to define viscosity by this function:
v=v0*exp(b(T-T0))*g^n where : v=viscosity b=constant T=temperatur g=shear rate
thanks for you kind help
Old   February 6, 2023, 17:06
Default Ostwald de Waele - Momentum Continuity Equation
arne711 is on a distinguished road
I am looking for some information about the implementation of the Ostwald de Waele Power Law into Ansys Fluent or OpenFOAM for a research project.
So if anyone could recommend an interesting paper or would even be able to share some code I would be really happy.
I would be especially interested in the modified momentum continuity equation. As far as I understand it's not hard to substitute the power law for the shear stress but I didn't find any information about solving it in a three dimensional geometry.
Thank you!
arne711 is offline   Reply With Quote
Old   October 30, 2023, 04:55
SHIVA
KOTTE SHIVA YADAV is on a distinguished road
hello @arne711
I am also stuck with same problem can you please help me in implementing Power law model in OpenFoam?
Thanks in Advance
KOTTE SHIVA YADAV is offline   Reply With Quote
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
Turbulence viscosity ratio Haitham FLUENT 5 February 5, 2008 04:49
Turbulence viscosity limited Madhukar Rapaka FLUENT 0 June 26, 2006 03:17
Wall turbulence, viscosity, boundary layer Patrick Godon Main CFD Forum 1 November 5, 2003 15:39
