hi i am simulating heatflow in air pre heater or rotary regenerator.iam not able to model rotary heat wheel with porous matrix which acts as heat source in half cycle and heat sink in another.heat wheel has corrugated steel sheets packed as matrix to increase the heat transfer area.Its a cross flow heat exchanger with flue gas and air as fluids.heat wheel extracts heat from flue gas and transfers it to air.I am not able to give porous charecteristics to rotary solid domain.i am using CFX-5.7.is it possible plz anyone can help me in this regard. regards kiran
Prakash Ghose
Rep Power: 14 ![]() |
Sir,
I think you already have done the simulation of rotary regenerator simulation fluent . Kindly guide me. I am trying it since a couple of month but could not able to do it. I requesting you for some clue, it will be a great help for me. Thank you. |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
Simulation of a Silo | Attesz | CFX | 20 | October 15, 2010 08:11 |
Problem with rotating SOLID domain | Roland R | CFX | 0 | May 8, 2009 03:38 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
Porous fow with rotating wall | Yi Wang | Main CFD Forum | 0 | August 19, 1998 09:03 |
