Error while trying to open Fluent file for setup |
drago
Rep Power: 0 ![]() |
Hello everyone,
I am working on ANSYS Fluent, and have successfully done modelling in Design Modeler and also done meshing of the geometry. Now, when i am trying to open it for setup it is showing error: Error: sopenoutputfile: unable to open file for output Error Object: "C:\\Windows\\system32\\cleanup-fluent-CADLAB01-27-11968.bat" > Reading "C:\Users\sa989\Desktop\research\researchchevron_f iles\dp0\FFF\MECH\FFF.msh"... Error: This appears to be a surface mesh. Surface meshes cannot be read under the /file/read-case functionality. Reading Cells: failed while reading section 12. Clearing partially read grid. Error: Read_Grid_Section: Aborted due to critical error. Error: Read_Grid_Section: Aborted due to critical error. Error Object: #f Error: No journal response to dialog box message:'Read_Grid_Section: Aborted due to critical error.' . Internally, cancelled the dialog. Error: Error reading "C:\Users\sa989\Desktop\research\researchchevron_f iles\dp0\FFF\MECH\FFF.msh". Error Object: #f Can you please tell me the way to solve the problem? |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 14:30 |
[OpenFOAM.com] swak4foam compiling issues on a cluster | saj216 | OpenFOAM Installation | 5 | January 17, 2023 16:05 |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
