Setting up pressure BC's and calculating local Cf in FLUENT
Old   May 22, 2023, 20:13
Default Setting up pressure BC's and calculating local Cf in FLUENT
Nate Werner
nwerner1 is on a distinguished road
I am looking to simulate the flow over a flat plate in 3D with pressure boundary conditions, and I have two questions.
1. For some context, I have separated the domain into two fluid regions, the bottom region is for the boundary layer, and the top is for the undisturbed flow. What type of boundary conditions in fluent should I apply to specify the pressure and prevent reverse flow? I have included some images of the named selections and the boundary conditions that result in Fluent; I'm not sure if this is sufficient.
2. I need to calculate the local skin friction coefficient along the wall. In this post
Originally Posted by Abhinand View Post
Skin friction coeff : From fluent (as field variable) By calculation : tau = mu*(dx-velocity-dy)
the field variable is compared with the shear stress calculation. How do I define an equation in Fluent to calculate Cf = tau/(0.5*rho*V^2)? This equation would give Cf for the whole plate, but I need to know Cf based on V at different x locations, and I can't choose the velocity at the wall because of no-slip. I'm not sure which V(x) I should use, I was considering using it at the top of the zone where I know the boundary layer will fit into it but I would not know how to program that in. If I can't program it in then I could use the velocity data after the simulation runs.
Sorry for rambling.
nwerner1 is offline   Reply With Quote
equation definition, fluent, pressure boundary, skin coefficient, workbench ansys
Pressure Outlet Guage pressure Mohsin FLUENT 36 April 29, 2016 17:16
Difference between HF and Temperature BCs Catthan FLUENT 0 August 7, 2013 05:59
Calculating Pressure Drop - BCs spoon OpenFOAM Running, Solving & CFD 1 February 25, 2013 18:47
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
