where to inter t0 for temperature dependent viscosity
Old   May 24, 2021, 17:40
Default where to inter t0 for temperature dependent viscosity
yahya rezvani
rezvani is on a distinguished road
Hello. in the fluent manual said
t0, which is the temperature shift, is set to 0 by default, and corresponds to the lowest temperature that is thermodynamically acceptable
. how to change this parameter? is it belong to reference value menu in fluent?
thank you.
best regards.
rezvani is offline   Reply With Quote
Multiphase non-Newtonian viscosity of blood mdmtramper Fluent Multiphase 3 January 22, 2021 06:09
Problem with divergence TDK FLUENT 13 December 14, 2018 06:00
Adding new temperature dependent viscosity model vabishek OpenFOAM Programming & Development 3 May 15, 2016 21:05
Problems in converging viscosity UDF dependent upon strain rate and temperature. alexskerhut Fluent UDF and Scheme Programming 1 March 17, 2016 07:19
Time and temperature dependent viscosity sur4j OpenFOAM 16 January 12, 2015 00:56
