Related to UDF
Like Tree1Likes
  • 1 Post By pakk
Old   April 12, 2021, 03:09
Default Related to UDF
msd
Heer
msd is on a distinguished road
Hello All,
I am trying to write a UDF for the pressure outlet boundary condition and the underlying condition is,
P = R*Q.
P = Mean pressure at the outlet (i.e. it remains constant at the whole face)
R = constant taken from literature
Q = flow rate
At the inlet, the pressure boundary condition is specified.
The code written goes as follows,
#include "udf.h"
#define R 12e9 /*Value taken from literature*/
#include "mem.h"
#include "metric.h"
DEFINE_PROFILE (outlet_pressure, thread, position)
real A[ND_ND];
face_t f;
Thread *t;
real Ar, V, Qfinal;
real Q = 0;
begin_f_loop(f, thread)
F_AREA(A, f, thread);
Ar = NV_MAG(A); /* Used for the computation of the magnitude of the area vector */
V = F_U(f, thread);
Q = Q + (Ar*V);
end_f_loop(f, thread)
Qfinal = Q;
F_PROFILE(f, thread, position) = R*Qfinal;
Can someone please tell if there is some logical error in the code because the relation P = R*Q is not getting satisfied.
Thanks in advance!
msd is offline   Reply With Quote
Old   April 12, 2021, 04:09
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
right before line: Qfinal = Q;
you need to add global summation macro to make code works in parallel
Q = PRF_GRSUM1(Q);
also I'm not sure if you need to use full outlet area of each finite are (as you did) here:
Q = Q + (Ar*V);
check it
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   April 12, 2021, 08:16
Yasser Selima
Yasser is on a distinguished road
  q += a[0] * v
q += a[0] * v;
Yasser is offline   Reply With Quote
Old   April 12, 2021, 10:32
msd
Heer
@Yasser, while inculcating this change, should I not calculate the magnitude of the area vector?
Old   April 12, 2021, 10:38
Yasser Selima
If you are considering F_U, you should be multiplying this time the area in the x-direction only!
Old   April 12, 2021, 10:39
msd
Heer
Thanks, Yasser for your input, I will check it.
Old   April 12, 2021, 10:40
msd
Heer
Thank you Alexander for your input, I will check if it works.
Old   April 13, 2021, 05:51
msd
Heer
Q = PRF_GRSUM1(Q);
Q = Q + (Ar*V);
check it
Dear Alexander,
I tried incorporating the change suggested by you and the modified code is as follows:
#include "udf.h"
#include "mem.h"
#include "metric.h"
#include "prf.h"
real A[ND_ND];
face_t f;
Thread *t;
real Ar, V, Qfinal;
real Q, P;
V = F_U(f, thread);
Q = Ar*V;
Q = PRF_GRSUM1(Q);
Qfinal = Q;
But I have a couple of questions, as in will the final pressure obtained be the same all over the face or some more modification is required? Also, I don't know why my relation is still not getting satisfied.
Can you please help?
Thanks!
Old   April 13, 2021, 11:30
msd
Heer
Dear Alexander,
I am facing one more problem, the volumetric flow rate calculated by the UDF (as I printed and checked the value), and the surface integral is coming different and it is differing by a value of order 10^(-3). But the relation is satisfied by the value of the volumetric flow rate obtained from the UDF and not from surface integral.
Can you please tell what can be the possible reason behind it?
Thanks in advance!
Old   April 17, 2021, 11:26
pakk will become famous soon enough
Q = Ar*V;
This is wrong, you only keep the value of the last cell.
Q += Ar*V;
msd likes this.
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build".
pakk is offline   Reply With Quote
Old   April 19, 2021, 02:23
msd
Heer
Originally Posted by pakk View Post
Q = Ar*V;
Q += Ar*V;
Thank you, I will try incorporating the changes.
average outlet pressure, udf
Want help regarding the UDF that is been written in VS code related to weber number saratunni07 CFD Freelancers 0 May 20, 2017 02:30
Problem in convergence regarding constant viscosity and UDF related Viscosity. alexskerhut FLUENT 0 May 9, 2016 08:43
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 00:53
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
DEFINE_DPM_OUTPUT macro UDF HELP Puneet FLUENT 3 November 28, 2003 10:55
