Question about output a self-defined variable in a line with corresponding coordinate |
April 17, 2021, 04:37 |
Darry He
I am using Fluent 19.2 and I am planning to output a self-defined variable in a line with corresponding coordinates. I have defined several lines. I write a wind profile as my inlet condition. The velocity profile on the boundary (the U∞ ) is only a part of my self-defined variable. Uw is the local velocity and can be easily obtained. But I still don't know how to get the value of 1-(Uw/U∞) along a specific line. Another question is how to get the value VS position at any given location? since the position and its value contained in the output file may not what I want. Thanks, Darry |
fluent; variable |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[OpenFOAM] ParaView command in Foam-extend-4.1 | mitu_94 | ParaView | 0 | March 4, 2021 13:46 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
