For the CFD, Which should be done first for grid independence or time step independen |
Rep Power: 9 ![]() |
For the CFD, Which should be done first for grid independence or time step independence?
I met a problem, when I increased the mesh number, the CFD process may sometimes diverge for sometimes, what should I do? Can I use the adaptive timestep to solve the problem? |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
It's like asking if you need to open your left eye first or your right eye first when you wake up. You're not awake until both eyes are open. Or whether you step forward with your left foot or your right foot when you walk.
You need to do both. |
#3 | |
Maybe you do not understand my question. As you know, when I increase the mesh number, the timestep also needs to decrease to ensure the Courant number<1, so it is impossible to acquire a fixed timestep. |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 07:47 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 22:40 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
