May 9, 2021, 10:56 |
Ansys Fluent meshing vs Ansys Meshing
Rep Power: 6 |
Hi all,
Thank you for reading this. I am fairly new to Ansys and I have been trying to simulate the flow around an airfoil. I was trying 2D and meshed using Ansys meshing. However I came across Ansys fluent meshing and I am confused now as of which one to be used? Also in Ansys fluent it has "water tight" feature would that work for an airfoil? Thanks In advanced. |
May 10, 2021, 03:15 |
Alexander
Rep Power: 34 |
you may use any mesher you prefer as fluent can read different formats
Fluent build-in meshe is very simple and effective. water-tight is just a name of workflow (contains the list of predefined options, which can be changed, removed or added) you may use it for external flows
best regards ****************************** press LIKE if this message was helpful |
How to get velocity at each node of meshing at each time-step in Ansys Fluent? | Mahram Khan | FLUENT | 4 | January 15, 2019 01:04 |
Ansys SIG$ILL error | loth | ANSYS | 3 | December 24, 2015 05:31 |
[ANSYS Meshing] Non-uniform meshing in ANSYS fluent | natty_celo | ANSYS Meshing & Geometry | 1 | January 12, 2015 23:59 |
[DesignModeler] Importing Solid Edge ST4 Geometry into Ansys Fluent 13.0 for meshing | The Mighty Rearranger | ANSYS Meshing & Geometry | 0 | November 27, 2012 12:44 |
Meshing In Ansys Workbench For Fluent (Refinement) | FAU_OceanEng | FLUENT | 0 | May 31, 2010 17:12 |
