Ansys Fluent meshing vs Ansys Meshing
Old   May 9, 2021, 10:56
Smile Ansys Fluent meshing vs Ansys Meshing
amd2424 is on a distinguished road
Hi all,
Thank you for reading this. I am fairly new to Ansys and I have been trying to simulate the flow around an airfoil. I was trying 2D and meshed using Ansys meshing. However I came across Ansys fluent meshing and I am confused now as of which one to be used?
Also in Ansys fluent it has "water tight" feature would that work for an airfoil?
Thanks In advanced.
amd2424 is offline   Reply With Quote
Old   May 10, 2021, 03:15
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you may use any mesher you prefer as fluent can read different formats
Fluent build-in meshe is very simple and effective.
water-tight is just a name of workflow (contains the list of predefined options, which can be changed, removed or added)
you may use it for external flows
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
How to get velocity at each node of meshing at each time-step in Ansys Fluent? Mahram Khan FLUENT 4 January 15, 2019 01:04
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 05:31
[ANSYS Meshing] Non-uniform meshing in ANSYS fluent natty_celo ANSYS Meshing & Geometry 1 January 12, 2015 23:59
[DesignModeler] Importing Solid Edge ST4 Geometry into Ansys Fluent 13.0 for meshing The Mighty Rearranger ANSYS Meshing & Geometry 0 November 27, 2012 12:44
Meshing In Ansys Workbench For Fluent (Refinement) FAU_OceanEng FLUENT 0 May 31, 2010 17:12
