September 2, 2021, 03:19 |
Prefered Solution Methods
SHARAJ PADMANABA
Attachment 86129I am Performing an air flow simulation over a unit to capture the Temperature signature in the interior of the unit and the exterior skin.Hence, I want to know the appropriate inputs to Apply in the Solution > Methods section.
Info :- Fully Solid Body > No openings > internal (FR4)PCB's given Convection Properties with Heat Generation> Outer Surface aluminum> Temp @ 27 - 55 -85`C> All assigned Wall Type. I am new to this forum, so do ask if any more inputs are needed. Thanks. |
Converging the solution | aja1345 | FLUENT | 13 | June 14, 2022 23:46 |
UDF for Automatic Solution Initialization for previous case data file | gartz89 | Fluent UDF and Scheme Programming | 6 | March 30, 2020 07:38 |
CAMWA special issue on open-source numerical solver | feixu2019 | OpenFOAM Announcements from Other Sources | 0 | October 1, 2018 11:21 |
Pressure distribution on a wall | darazsbence | CFX | 17 | October 6, 2015 10:38 |
Exact solution of Burgers equation | mcaro | Main CFD Forum | 3 | January 25, 2011 06:46 |
