Mapping of heat transfer coefficient.
Old   October 13, 2021, 01:20
Default Mapping of heat transfer coefficient.
Arun Issac
eternallearnerishak is on a distinguished road
Hey all,
I am doing a heat transfer problem. I divided the problem into two simulations. The first one is an external flow over a heated body. From this simulation, I will get the heat transfer coefficients(HTC) and in the second simulation, I am planning to do a CHT simulation where I need to use the HTC that I got from the external flow simulation.
Currently, I am assigning the area-averaged HTC from the external flow simulation to the CHT simulation. What I need is a one-to-one mapping of the HTC to CHT simulation since both are done in the same geometry.
Thanks for the help.
eternallearnerishak is offline   Reply With Quote
Old   October 13, 2021, 02:35
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
write to profile HTC from simulation and apply it as boundary condition
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   October 13, 2021, 03:18
Lorenzo Galieti
LoGaL is on a distinguished road
agree with Alexander. However, i am confused on why you don't simulate the full problem in one run.
LoGaL is offline   Reply With Quote
Old   October 13, 2021, 13:18
Arun Issac
Thank you, Will try it.
Old   October 13, 2021, 13:23
Arun Issac
The reason why i simulate the problem separately is because of the mesh number of elements. What i am try to simulate is a heat transfer analysis of electrical motor which is cooled by external forced convection. So if i am simulating both external and internal fluids(there is air inside the motor), then my mesh count will be very high which makes the problem computationally limiting for me.
Thanks for your reply.
cht coupling, fluent, htc
Calculating local heat transfer coefficient for Cylindrical fins karyan07 FLUENT 0 April 28, 2021 23:47
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 01:27
Heat flux and Heat transfer coefficient sakil2k3 FLUENT 4 July 5, 2015 15:07
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade Karkoura CFX 0 March 10, 2011 15:35
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
