Pressure Inlet BC Inputs
Old   October 29, 2021, 15:48
Question Pressure Inlet BC Inputs
Kevin Davis
kdavis1521 is on a distinguished road
I'm attempting to do a pressure inlet boundary condition for a supersonic oxygen inlet. The values given for the inlet are 914,468 Pa for stagnation pressure, 2.1 for mach number and 298 K for total temperature.
I was under the impression that stagnation pressure would be entered into "Gauge Total Pressure" and the "Supersonic/Initial Gauge Pressure" could then be calculated as static pressure using the isentropic flow relation, resulting in a value of 100,000 Pa. However, when I enter these values I end up with an initial velocity that is more than double what is expected for this oxygen jet. I am struggling to figure out what I am doing wrong and would greatly appreciate if anyone could provide any help. Thanks.
kdavis1521 is offline   Reply With Quote
Old   October 29, 2021, 18:52
Lorenzo Galieti
LoGaL is on a distinguished road
is the operating pressure set to zero?
LoGaL is offline   Reply With Quote
Old   October 29, 2021, 19:55
Kevin Davis
No it was not. This fixed my solution, thank you.
pressure inlet, stagnation pressure, supersonic
Adjuting oulet pressure till inlet pressure reaches a certain value in timestep pvpnrao OpenFOAM Running, Solving & CFD 2 September 11, 2018 10:14
"Pressure Inlet" Boundary Setup Wijaya FLUENT 15 May 18, 2016 10:08
Assign static pressure at inlet Tanjina FLUENT 0 November 3, 2013 11:34
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
