October 29, 2021, 15:48 |
Pressure Inlet BC Inputs
Kevin Davis
I'm attempting to do a pressure inlet boundary condition for a supersonic oxygen inlet. The values given for the inlet are 914,468 Pa for stagnation pressure, 2.1 for mach number and 298 K for total temperature.
I was under the impression that stagnation pressure would be entered into "Gauge Total Pressure" and the "Supersonic/Initial Gauge Pressure" could then be calculated as static pressure using the isentropic flow relation, resulting in a value of 100,000 Pa. However, when I enter these values I end up with an initial velocity that is more than double what is expected for this oxygen jet. I am struggling to figure out what I am doing wrong and would greatly appreciate if anyone could provide any help. Thanks. |
October 29, 2021, 18:52 |
Lorenzo Galieti
Rep Power: 12 |
is the operating pressure set to zero?
October 29, 2021, 19:55 |
Kevin Davis
No it was not. This fixed my solution, thank you.
pressure inlet, stagnation pressure, supersonic |
Adjuting oulet pressure till inlet pressure reaches a certain value in timestep | pvpnrao | OpenFOAM Running, Solving & CFD | 2 | September 11, 2018 10:14 |
"Pressure Inlet" Boundary Setup | Wijaya | FLUENT | 15 | May 18, 2016 10:08 |
Assign static pressure at inlet | Tanjina | FLUENT | 0 | November 3, 2013 11:34 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
