Simulation of non-newtonian fluid giving bad results? |
November 9, 2021, 20:29 |
New South Wales
Rep Power: 4 |
Hi all,
I am attempting to simulate the flow of blood through an arterial system in the brain and then measure the wall shear at a point in a particular artery. My system contains 2 inlets with mass flow conditions and a large range of outlets with relative pressure conditions. During simulation i get lots of messages saying that flow has reversed in the outlets and I am getting ridiculous results of a constant pressure through the entire system of 170MPa? Why would i be getting these ridiculous results with a very minuscule mass flow at the inlet? Thanks in advance |
November 10, 2021, 02:38 |
Lorenzo Galieti
Rep Power: 12 |
It maybe that the combination of pressure outlet and mass flow inlet is not feasible for the viscosity ( and pressure drop) associated. How are you selecting the non newtonian fluid properties? I bet my money on out of the chart viscosity values… I would expect blood to be ~4 times less viscous than water
November 10, 2021, 06:05 |
New South Wales
Rep Power: 4 |
For the non-newtonian fluid (blood) i used a density from literature and used the carreau model for the viscosity, again with parameters from other literature
November 10, 2021, 06:25 |
Lorenzo Galieti
Rep Power: 12 |
Ok so we have density which is more or less the one of water and some model for viscosity right? Which values of viscosity you get? Could you plot a dynamic viscosity contour? It has to be basically less then water viscosity
November 11, 2021, 22:14 |
New South Wales
Rep Power: 4 |
Shouldn't blood be more viscous than water rather than less? I re-ran the simulation this time without a non-newtonian model for viscosity, just a constant value and kept everything else the same. Regardless I am still running into the same issue of having a constant pressure at every point in the system as well as a wall shear stress of zero and reversed flows at the outlets
November 11, 2021, 22:58 |
Alexander
Rep Power: 34 |
which model are you using for density?
going back to your first question, you have abnormal pressure because of problem in case settings. go step by step through each setting and check carefully. try to find reference cases in google / youtube
best regards ****************************** press LIKE if this message was helpful |
November 12, 2021, 16:05 |
Lorenzo Galieti
Rep Power: 12 |
if you get the same issue using a normal viscosity model, alexander is right. It unfortunately has to be some stupid mistake around in the setup, we all make them.
You say mass flow inlet, pressure outlet. Constant density? (This one i am sure it is basically water). Is the operating pressure set to zero or to a number? Did you check mesh quality? Concerning blood viscosity, shouldn't it be less, at least in tiny vessels? |
November 14, 2021, 22:59 |
New South Wales
Rep Power: 4 |
Thank you for all the help guys. I have gone back through my set up, and have changed the outlets to "outflow" rather than a pressure outlet and this has seemed to fix the problem. How does operating pressure affect my solution and what value should this be set too?
While the constant pressure has been fixed i am still getting reverse flow at the outlets and very unrealistic pressure values across the system (Between 1-2MPa). Could this be related to the operating temperature? |
Fluent Multiphase simulation with one single-phase fluid | jykim | Fluent Multiphase | 1 | April 11, 2020 09:06 |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 06:08 |
Problem with an old Simulation | FrankW | CFX | 3 | February 8, 2016 04:28 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
