December 14, 2021, 09:17 |
Forces on a rotating aerofoil
Rep Power: 6 |
Hello all,
I know the topic of lift and drag for rotating aerofoils has been discussed many times on the forum. But I have a specific question and would really appreciate the help. I am trying to extract the lift and drag forces on a rotating airfoil of a vertical axis wind turbine. But to my best understanding, in Fluent when you monitor the lift and drag forces on a rotating object it basically monitors the forces in the X and Y direction. Where X corresponds to drag (parallel to inflow velocity) and Y corresponds to lift(perpendicular to inflow velocity). Could any of you please help me with going from these force values to the actual aerofoil lift and drag values(perpendicular and parallel to the relative flow velocity at the aerofoil)? It is essentially like going from a global reference frame to a local reference frame, I think. Thanks in advance! |
December 14, 2021, 23:26 |
Alexander
Rep Power: 34 |
when you are creating monitor for lift/drag you should specify vector.
this is what you are looking for same approach when you are obtaining lift/drag through reports panel
best regards ****************************** press LIKE if this message was helpful |
December 15, 2021, 07:35 |
Rep Power: 6 |
Hi Alexander,
Thank you for your response. If I want to specify the vector as you suggest, I would need to do that at every timestep during the rotation, right? I would also need to know the direction of the relative velocity at the quarter chord to determine this vector at every timestep if I understand correctly. So far, I see the same values when I visualise both velocity magnitude and absolute velocity magnitude. Could you please help me with some suggestions on how to find the correct relative velocity components from Fluent? Thanks again! |
forces on rotating bodies, vawt wind turbine |
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" | ds4719 | Main CFD Forum | 14 | February 18, 2022 18:05 |
Residuals and forces spiraling out of control before failing | edomalley1 | OpenFOAM Running, Solving & CFD | 3 | September 7, 2018 10:42 |
Car external aerodynamic with wheel spinning issue | hokhay | FloEFD, FloWorks & FloTHERM | 2 | August 18, 2016 04:23 |
Forces Acting on a Rotating Cylinder (Moving Mesh) | dreamchaser | CFX | 5 | April 25, 2015 06:01 |
2D Aerofoil with rotating cylinders - Help & Advice! | Bluejay | OpenFOAM | 1 | December 31, 2012 04:40 |
