ANSYS Fluent errors "Attach Failed" and "No Valid bodies Found"
Old   September 23, 2017, 18:49
Default ANSYS Fluent errors "Attach Failed" and "No Valid bodies Found"
bert
Bertman is on a distinguished road
Hello everyone,
I was doing some simulations on ANSYS Workbench 18.1 and when I imported solidwork files (two semi trucks in convoying situation) and try to edit the use DesignModeler I get two errors that say Attach Failed and no valid bodies found.
The solid work drawling are two semi trucks in a convoying situation which is just an assembly of two semi trucks. But when I use only one semi truck ANSYS has no problems and runs the simulations with no problems. Does anyone have any thoughts on how I could fix the error?
Thank you
Bertman is offline   Reply With Quote
Old   September 24, 2017, 08:44
Johannes Johannes
S_John is on a distinguished road
I have ANSYS 16.2 student version and im trying to import models from Solidworks but i either get a zero geometry or this error: "ANSYSLI exited or could not read server port ANSYSLI_DEMO_PORT."
please somebody help i want to use it for my final year project.
S_John is offline   Reply With Quote
Old   September 25, 2017, 11:02
Elgadari
Elgadari is on a distinguished road
Hi Guys
Did you import STP file? if not, please try to export the solidworks model to STP file and then import it to Fluent
I am not sure but I hope this will help you
Elgadari is offline   Reply With Quote
Old   December 24, 2021, 17:15
sadsid is on a distinguished road
Any solution to this problem. I am facing the same.
sadsid is offline   Reply With Quote
