Underelaxation factor density - convergence problem
Old   February 13, 2022, 13:18
Unhappy Underelaxation factor density - convergence problem
Karla Jacinto
karlag is on a distinguished road
I'm trying to solve a high turbulent two-phase flow by using UDF to read the fluid properties.
I'm having problems converging the solution once the continuity residual gets flat, with some oscillations around the value of 1e-1. In that case, the solution is very unstable, changing completely between iterations.
If I increase the under-relaxation factor for Density the residual keeps growing until it reaches floating point error.
I tried to converge only on the flow equations, but the problem persists.
For the initialization, I used the real gas solution (that converged).
Please, if you have any strategy for me, I will be grateful. Ah, I'm using pressure-based and the scheme is couple.
karlag is offline   Reply With Quote
cfd, convergence failure, turbulence, two-phase
Convergence problem in Fluent for quenching process kaeran FLUENT 4 December 1, 2014 02:14
Rotate frame reference convergence problem! wjy-c CFX 2 September 26, 2014 06:03
Centrifugal pump OpenFOAM, convergence problem, ANSA model RDD OpenFOAM Running, Solving & CFD 0 July 5, 2014 09:12
Convergence Problem in Axisymmetric Periodic Flow atheresia FLUENT 3 February 10, 2014 03:00
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
