Slow continuity convergence on command line run |
February 17, 2022, 06:17 |
ishan
Rep Power: 8 |
I am running a Detached Eddy Simulation with SST k-omega for a simple geometry with 16 million cells(unstructured). I noticed that when I run the Fluent case from the command line on CentOS, the continuity equation never converges even after 30 iterations per time step. It gets stuck at e-2 levels. However, when I run it in GUI mode, the levels do reach e-3 levels at 15 iterations/time step. This is the command I am using to run: Code:
sh fluent 3d -g -t36 -i journal_file.jou >& outputfile & I do not have any software such as PBS. I have never encountered this issue before. Your help on this issue will be appreciated. |
How to use PIMPLE properly? | floquation | OpenFOAM Running, Solving & CFD | 25 | December 2, 2021 09:40 |
chtMultiRegionSimpleFoam won't restart. P or T divergence. Continuity? | MarkYB | OpenFOAM Running, Solving & CFD | 3 | March 11, 2021 03:25 |
time step continuity problem in VAWT simulation | lpz_michele | OpenFOAM Running, Solving & CFD | 5 | February 22, 2018 19:50 |
Convergence problem with continuity equation in microchannels.. | vikasy123 | FLUENT | 2 | October 14, 2015 02:33 |
Help for the small implementation in turbulence model | shipman | OpenFOAM Programming & Development | 25 | March 19, 2014 10:08 |
