February 17, 2022, 06:55 |
Export case in ascii
Nico
Rep Power: 6 |
Hey everyone!
i would like to export my fluent case as .cas in ascii. How can i do this? I know how to export the mesh in ascii, but i am not certain how to do this for the case, since i would like to preserve the coupled walls. I am using Ansys fluent 2021 r1. Thanks in advance! |
February 17, 2022, 08:45 |
Lucky
Rep Power: 66 |
In the GUI, you just uncheck the box that says binary when you go to write the case file and the prompt window opens up asking you where to save and what the filename should be.
In the TUI you type Code:
/file/binary-files? no |
February 17, 2022, 09:42 |
Nico
Rep Power: 6 |
Thank you! Please correct if i am wrong, but if i export from the fluent module i don't have said checkbox for binary. Is the command line alone sufficient to write in ASCII?
Pressure instabilities with interDyMFoam for the floatingObject case | nbadano | OpenFOAM Running, Solving & CFD | 15 | October 15, 2021 06:35 |
[OpenFOAM.com] Problem installation OpenFOAM 6 | wamars | OpenFOAM Installation | 0 | June 23, 2020 09:01 |
[foam-extend.org] foam-extend-4.0 gcc errors & maybe paraFoam | powerline332 | OpenFOAM Installation | 3 | May 24, 2018 21:16 |
Cfd-post - how to export figures automatically? | antonio_dcp | CFX | 1 | October 26, 2017 18:10 |
OpenFOAM gcc configuration problem | preacher | OpenFOAM Installation | 7 | March 3, 2014 22:44 |
