Error in udf-Excuted on demand -parallel mode |
February 22, 2022, 01:06 |
masoud fard
Rep Power: 4 |
Dear freinds
The following UDF is just working in "SERIAL" processing option without problem, but in the "PARALLEL" mode, when the Excuted on deman is selected, this error appear"Node 999999: Process 12480: Received signal SIGSEGV. MPI Application rank 0 exited before MPI_Finalize() with status -1 The fl process could not be started. " The udf is interpreted without any problem, but dosnt work in parallel mode. Please let me know your suggestions. #include "udf.h" DEFINE_ON_DEMAND(on_demand_calc) { Domain *d; /* declare domain pointer since it is not passed as an argument to the DEFINE macro */ real R=8.314; real D=26.1e-6; float Y_W,X_W,Y_A; "mole fraction and mass fraction of vapor" float T_cell, P_cell, P_sat,Powsat; Thread *t; cell_t c; d = Get_Domain(2); /* Get the domain using ANSYS Fluent utility */ /* Loop over all cell threads in the domain */ thread_loop_c(t,d) { Y_W = C_YI(c,t,0); Y_A = C_YI(c,t,1); X_W = (Y_W*29)/((29*Y_W) + (18*Y_A)); T_cell = C_T(c,t); /*cell mixture temperature*/ P_cell = C_P(c,t); Powsat=(8.07131-1730.63/(233.426+(T_cell-273.15))); P_sat = pow(10,Powsat)*133.322; /* Loop over all cells */ begin_c_loop(c,t) { C_UDSI(c,t,0) = C_VOF(c,t); C_UDSI(c,t,1) = C_YI(c,t,0); C_UDMI(c,t,1)=NV_MAG(C_UDSI_G(c,t,0)); C_UDMI(c,t,2)=NV_MAG(C_UDSI_G(c,t,1)); C_UDMI(c,t,4)= pow(C_VOLUME(c,t),0.66)*3; if (C_UDMI(c,t,1)>40) { C_UDSI(c,t,1)=P_sat/ P_cell; C_UDMI(c,t,2)=NV_MAG(C_UDSI_G(c,t,1)); C_UDMI(c,t,0)=D*P_cell/(R*T_cell)* C_UDMI(c,t,2)*C_UDMI(c,t,4); C_UDMI(c,t,5)=D*P_cell/(R*T_cell)* C_UDMI(c,t,2); } else {C_UDMI(c,t,0)=0;} } end_c_loop(c,t) } } DEFINE_MASS_TRANSFER(mass_transfer1, c, t, from_phase_index, from_species_index, to_phase_index, to_species_index) { float m_lg, T_cell, P_cell, P_sat,Powsat; float NV_VEC(G); float X_W, Y_W, Y_A; float cur_ts; Thread *w_liq, *gas_mix, *w_gas; face_t f; Domain *mix_domain, *pdomain; int i, pdomain_index; float area[ND_ND], A, ad, theta, cotan, len; /******** Define variables *********/ mix_domain = Get_Domain(1); /* pdomain = DOMAIN_SUB_DOMAIN(mixture_domain,2); */ /* For gas domain */ pdomain_index = 0; pdomain = DOMAIN_SUB_DOMAIN(mix_domain,pdomain_index); w_liq = THREAD_SUB_THREAD(t, from_phase_index); gas_mix = THREAD_SUB_THREAD(t, to_phase_index); w_gas = THREAD_SUB_THREAD(t, to_species_index); T_cell = C_T(c,t); /*cell mixture temperature*/ P_cell = C_P(c,t); /*cell mixture pressure*/ m_lg = ABS(C_UDMI(c,t,0)); C_UDMI(c,t,3)=m_lg; return (m_lg); /* return value of mass transfer rate */ } Last edited by fard734; February 22, 2022 at 03:34. |
February 22, 2022, 20:43 |
Alexander
Rep Power: 34 |
it should work in parallel either.
check again if you've allocated udmi and udsi memories in fluent GUI you may try to compile udf instead of interpret it.
best regards ****************************** press LIKE if this message was helpful |
does Hyperthreading affect the application of UDF? | SJSW | Fluent UDF and Scheme Programming | 11 | October 10, 2018 22:28 |
Debug mode with UDF ?? | Thierry | FLUENT | 1 | October 9, 2018 21:57 |
Error code: 126 when loading parallel UDF | Coop | Fluent UDF and Scheme Programming | 0 | July 13, 2018 08:33 |
Source Term UDF VS Porous Media Model | pchoopanya | Fluent UDF and Scheme Programming | 1 | August 28, 2013 06:12 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
