February 15, 2018, 16:23 |
6DOF - 1DOF translation large forces
Emil Pedersen
Hi all,
So im new to fluent, and i want to simulate the opening of a check valve by simulating a spring force on one face of the valve and the fluid pressure on the other. I want to do this in 2D I have set this up with the 6DOF solver and set it to 1DOF translation with a small spring constant of 20N/m. The fluid is water, and i've set a velocity inlet based on a UDF where the flow is = 10*current_time, up until 0.02s when the flow is 0.2m/s. The outlet is a pressure outlet with 0pa static pressure. My problem is that unless i use very very small time steps of 1e-10 s, even at very small flow rates, the solver spits out huge resulting forces on the face of the valve. This only happens for fluids with high densities, if i use air for example, i am able to simulate the valve movement just fine. What could the issue be? i have uploaded a pic of the pressure contour. The inlet is to the left. This is at a time step in the order of 1e-09 seconds. |
February 18, 2018, 07:19 |
#2 | |
ram
Rep Power: 13 |
show boundary conditions on the picture when you used air, have you seen the valve seat moves? |
March 5, 2022, 09:40 |
mohammad
Rep Power: 4 |
Hi
I have the same problem. In every time steps force value going to infinity. I'm so glad if someone help me. Thanks |
March 5, 2022, 18:16 |
Marcin
Rep Power: 9 |
Try solution stabilization.
In dynamic mesh panel, for the selected zone (I guess, wall absorbing the pressure forces), you will have a panel called Solution stabilization, try the volume based, starting from small Scale factor values |
6dof, check valve, large force |
Reading forces from previous time step within solver | SD@TUB | OpenFOAM Programming & Development | 5 | April 24, 2023 11:51 |
Wedge Impact Forces (6DOF high velocity problem) | der_meister | FLUENT | 1 | June 14, 2010 23:32 |
Forces calulated through pressure | LVDH | OpenFOAM Post-Processing | 2 | February 26, 2010 03:15 |
Calculate forces without hydrostatic pressure | geir_oye | FLUENT | 4 | November 12, 2009 09:12 |
Valve Forces in CFdesign | Mike Clapp | Main CFD Forum | 3 | March 8, 2001 14:09 |
