residual storage in FLUENT
Like Tree16Likes
Old   September 20, 2007, 21:45
Default residual storage in FLUENT
sophie
residual storage in FLUENT?
i can't find residual values in my dat files,what's wrong???
can anyone tell me why?
thanks a lot!
Old   September 21, 2007, 05:08
Default Re: residual storage in FLUENT
Joe
you need to tell fluent to store the residuals in the dat file.
Old   September 21, 2007, 05:11
sophie
how to tell fluent to store the residuals in the dat file?
i'm not so familar with the TUI,can you tell me?
Old   September 21, 2007, 06:08
mAx
The following steps can be used to write the solution residuals to a text file.
1. Read the case/data files in FLUENT.
2. Read the Scheme file (init.scm) using the File-->Read-->Scheme command. The content of the Scheme file should be as follows (please copy the content between the dashed line into a text file and save it as 'init.scm'):
-------------------------------------------------------------- (define port) (set! port (open-output-file "residuals.dat"))
(do ((i 0 (+ i 1))) ((= i (length (solver-residuals)))) (format port "~a ~2t" (car (list-ref (solver-residuals) i))) ) (newline port) ---------------------------------------------------------------
3. Set the following execute command at every iteration using Solve --> Execute Commands:
file read-journal residual.jou
The content of the journal file (residual.jou) should be as follows (please copy the content between the dashed line into a text file and save it as 'residual.jou'):
--------------------------------------------------------------- (do ((i 0 (+ i 1))) ((= i (length (solver-residuals)))) (format port "~a ~2t" (cdr (list-ref (solver-residuals) i))) ) (newline port) ---------------------------------------------------------------
4. Now compute the solution using the Solve->Iterate command. This will write out a text file ('residuals.dat') containing the solution residual history.
Old   September 21, 2007, 23:48
sophie
thanks a lot!
that really works well!
but how to write these scheme command lines?
or must i learn the scheme language?
i have some german document,but i don't say german...
any suggestions?
Old   September 24, 2007, 21:02
sophie
new question:
now i have to execute the storage process through TUI, but it interrupts with the following error message:
Error: A journal is currently open for input or output. You cannot read and write a journal at the same time, or read two journals simultaneously. Error Object: #f
can anybody give me some advices?
urgent sophie
mostafadehghani.62 likes this.
Old   September 24, 2007, 21:17
sophie
now i want to describe me error exactly:
i want to store the residual which print in console to be a file,but my process is executed though TUI,i write these commands in my journal file:
;-------------------------------------------------------------- (define port) (set! port (open-output-file "residuals.dat"))
(cx-gui-do cx-activate-item "MenuBar*SolveMenu*Execute Commands...")
(cx-gui-do cx-set-integer-entry "Execute Commands*IntegerEntry1(Defined Commands)" 1)
(cx-gui-do cx-activate-item "Execute Commands*IntegerEntry1(Defined Commands)")
(cx-gui-do cx-set-toggle-button "Execute Commands*Frame2*Table2*CheckButton6" #f)
(cx-gui-do cx-activate-item "Execute Commands*Frame2*Table2*CheckButton6")
(cx-gui-do cx-set-text-entry "Execute Commands*Frame2*Table2*TextEntry10" "(do ((i 0 (+ i 1))) ((= i (length (solver-residuals)))) (format port "~a ~2t" (cdr (list-ref (solver-residuals) i))) ) (newline port)")
(cx-gui-do cx-activate-item "Execute Commands*PanelButtons*PushButton1(OK)")
(cx-gui-do cx-activate-item "Solution Initialization*PanelButtons*PushButton2(Cancel)")
solve/initialize/compute-defaults/pressure-far-field
solve/iterate 20 ;--------------------------------------------------- but the error message:
Error: eval: unbound variable Error Object: ~a
Warning: An error or interrupt occurred while reading the journal file. Some commands may not have been completed.
if i change the line contain ~a to be:
(cx-gui-do cx-set-text-entry "Execute Commands*Frame2*Table2*TextEntry10" "file read-journal residual.jou")
and in the content of the residual.jou is as follows
;--------------------------------------------------------------- (do ((i 0 (+ i 1))) ((= i (length (solver-residuals)))) (format port "~a ~2t" (cdr (list-ref (solver-residuals) i))) ) (newline port) ;---------------------------------------------------------------
the error message: file read-journal Error: A journal is currently open for input or output. You cannot read and write a journal at the same time, or read two journals simultaneously. Error Object: #f residual.jou invalid command [residual.jou]
can you give me some advices?
thanks a lot!
sophie
Old   May 12, 2014, 02:24
mostafa
mostafadehghani.62 is on a distinguished road
i have this problem too. there is any alternative for using "" in scheme?
mostafadehghani.62 is offline   Reply With Quote
Old   April 5, 2016, 22:22
Default How to add time step or time flow before the residuals??
Abdullatif A. Gari
agari is on a distinguished road
Originally Posted by mAx
;145582
Thank you very much.
Doing the above commands writes a list of residuals without the time flow or time step. Is there a way to do that?
How to add time step or time flow before the residuals?? (Either one)
agari is offline   Reply With Quote
Old   April 6, 2016, 09:02
Lucky
You can just edit the scheme so far and tell it to print the time-step and flow-time. The scheme variable names for these are time-step and flow-time.
rarnaunot likes this.
Old   April 6, 2016, 12:29
Abdullatif A. Gari
Thanks. But not familiar with c++ prog so where to put it? Like this:
(do ((i 0 (+ i 1))) ((= i (length (flow-time, solver-residuals)))) (format port "~a ~2t" (car (list-ref (solver-residuals) i))) ) (newline port)
Old   June 5, 2017, 11:22
Rosario Arnau
rarnaunot is on a distinguished road
Hello!
Did it work?
I have tried with:
(do ((i 0 (+ i 1))) ((= i (length (flow-time, solver-residuals)))) (format port "~a ~2t" (car (list-ref (flow-time, solver-residuals) i))) ) (newline port)
and
(do ((i 0 (+ i 1))) ((= i (length (time-step, solver-residuals)))) (format port "~a ~2t" (car (list-ref (time-step, solver-residuals) i))) ) (newline port)
and always get the same error:
Error Object: time-step
Error Object: flow-time
rarnaunot is offline   Reply With Quote
Old   June 5, 2017, 17:02
Lucky
Btw folks, in Fluent v18 residuals are available as a report so that you don't need these silly workarounds to write the residuals to a file. You still need a reader though.
rarnaunot and KaLium like this.
Old   June 6, 2017, 06:23
Rosario Arnau
Thaks! Really good news!
I was searching for it in 18 version. I guess it may be on: Report Files> Create a new Report File > New Report Definitions..... but how to get the residuals of the continuity, velocities and my different UDS?
Should I create my own Report with DEFINE_REPORT_DEFINITION_FN ?
Old   June 6, 2017, 09:06
Lucky
Oops. I might have confused myself after glancing at the original post. I was thinking you could write all cell residuals as a data file... by using
solve/set/expert n y n n (the defaults are n n n n)
This enable access to the cell residuals and then defining reports or using solution data export. A sum over all cells I think is what the Fluent window output is using (it might be another averaging operation), you should test it if you want to be sure.
This approach really should be doable in versions before 18 as well.
Old   June 6, 2017, 09:17
Rosario Arnau
Sorry! Maybe I didn't explain myself correctly. As u said, I want to copy to a file the plotted residuals or the numbers appearing in the command window, for example:
iter continuity x-velocity y-velocity z-velocity uds-0 uds-1 uds-2 uds-3 uds-4 time/iter
! 116 solution is converged
116 0.0000e+00 0.0000e+00 0.0000e+00 0.0000e+00 4.5547e-08 6.3906e-07 4.5547e-08 5.2988e-08 1.5437e-08 0:00:00 20
117 0.0000e+00 0.0000e+00 0.0000e+00 0.0000e+00 4.3878e-08 1.5746e-03 4.3878e-08 2.5311e-04 4.0493e-05 0:00:00 19
! 118 solution is converged
118 0.0000e+00 0.0000e+00 0.0000e+00 0.0000e+00 4.5545e-08 6.3959e-07 4.5545e-08 5.0686e-08 1.2597e-08 0:00:00 18
Old   January 18, 2018, 07:55
EmiS is on a distinguished road
Dear rarnaunot,
I have the exact same issue as you.
I'm currently using Fluent v18.2 with the following lines in my journal file:
/solve/set/expert yes no no
/plot/residuals-set/plot-to-file "Residuals.txt"
This only creates an empty text file as you mentioned.
Besides, I have also tried the work around with the scheme file (described at several places on this forum) but it also doesn't work. In this case I get a text file with only one line of residuals that gets re-written at every iteration as described in the second part of my post:
Saving the residuals in a dat file from TUI
Any help would be greatly appreciated here.
Cheers,
EmiS
EmiS is offline   Reply With Quote
Old   January 27, 2018, 22:45
Abdulaziz Abutunis
ama294 is on a distinguished road
Hi EmiS,
I have the same problem and wonder if you have figured it out. If so would you please share your thoughts.
Regards,
Aziz
ama294 is offline   Reply With Quote
Old   January 31, 2018, 17:38
Dear Aziz,
Sorry I still haven't figured out how to save the residuals properly in a text file from the TUI journal. The "poor-man" solution I'm using is to save the log history into a text file and use a Python script to parse through the file, save the information about the residuals and plot it.
EmiS
Old   February 1, 2018, 00:19
Abdulaziz Abutunis
Thank you EmiS for your reply I really appreciate it
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
Velocity blows up suddenly after 30,000+ iterations lordvon OpenFOAM Running, Solving & CFD 15 October 19, 2015 13:52
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Low Mach number Compressible jet flow using LES ankgupta8um OpenFOAM Running, Solving & CFD 7 January 15, 2011 13:38
MRFSimpleFoam amp cyclic patches david OpenFOAM Running, Solving & CFD 36 October 21, 2008 21:55
