How to save viscous drag force and pressure drag force at each time step ? |
July 12, 2022, 04:05 |
Alexis DUBOIS
I would like to save pressure drag force and viscous drag force at each iteration or time step in a same file. I know how to save them in different files. -> Results -> Compute forces -> Create a macro to save files at each iteration or time step. However, I would like to save them in a same file like that : Iteration Viscous Force Pressure Force Total Force 0 0.25 0.25 0.5 1 0.3 0.3 0.6 2 0.4 0.4 0.8 ... ... ... ... Can you help me ? Have a nice day. |
July 12, 2022, 12:11 |
Lucky
Rep Power: 66 |
When Fluent asks to Overwrite? choose no and it will append instead. Or is your setup special and you do not get this prompt?
July 18, 2022, 03:54 |
Alexis DUBOIS
Thank you for your reply, it works.
July 30, 2022, 08:28 |
MEK
Rep Power: 9 |
Can u share the macro to save file.
August 5, 2022, 03:44 |
Augustin MOREL
Rep Power: 3 |
/report/forces/wall-forces no 2 () 1 0 yes "Report-drag-forces" yes no : because I don't want a report for all zones 2 : the id of the zone that I want 1 : x-Component 0 : y-Component yes : to write a file "Report-drag-forces" : name of the file yes : append new values in the same file I write this in : Solution > Calculation activities > Execute commands |
August 6, 2022, 05:20 |
MEK
Rep Power: 9 |
Thank u so much
drag forces, fluent, pressure force, viscous force |
Convergence problem of OF | WUYing | OpenFOAM Running, Solving & CFD | 2 | September 20, 2021 10:09 |
interDyMFoam with VOF + 6DOF instable | pbalz | OpenFOAM Running, Solving & CFD | 11 | October 9, 2020 05:19 |
Residuals and forces spiraling out of control before failing | edomalley1 | OpenFOAM Running, Solving & CFD | 3 | September 7, 2018 10:42 |
Dam Break sigFpe Error | aow | OpenFOAM Running, Solving & CFD | 2 | May 24, 2018 14:32 |
udf for compute pressure drag force | fatemi | Fluent UDF and Scheme Programming | 1 | January 26, 2018 13:27 |
