Wall Surface Reaction with no species diffusion through reaction wall |
August 3, 2022, 14:26 |
Zach
Rep Power: 3 |
I am using FLUENT to make a 2D model of a a 50um x 1.5cm microfluidic channel, and I want to use the Species Mixing model with wall reaction to model living cells on the bottom consuming O2 and producing N2. I use a site-specific molecule silicon as a surface-bound catalyst to model the cells.
The flow in this channel is very low: 2.5nL/s, giving a maximum flow velocity of around 7.5e-5m/s. The diffusion coefficient for oxygen in water is 3e-9m2/s, which makes diffusion significantly faster than the convection. When I set up this model, I find that the O2 flowing in from the inlet rapidly diffuses out of the chamber through the reaction wall, as does the N2 produced by the reaction. I would like for the O2 to slowly be depleted as it reacts with the surface-bound catalyst, slowly filling the chamber with N2. Is there any way to write a UDF that specifies no O2 or N2 species diffusion through the walls? Is there a way to specify zero diffusive flux through a reaction wall? |
OpenFOAM error | Vinay Kumar V | Main CFD Forum | 0 | February 20, 2020 09:17 |
Homogeneous reaction works fine alone but not with diffusion and/or convection | Anderson2019 | Main CFD Forum | 1 | October 5, 2019 09:12 |
heat realease in wall by surface reaction (FLUENT) | Marie-Anne | Main CFD Forum | 4 | March 20, 2006 09:15 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 00:07 |
