Y+ effect on k-omega model to analyze sloshing phenomenon in a tank
Old   September 14, 2022, 02:48
Exclamation Y+ effect on k-omega model to analyze sloshing phenomenon in a tank
Federal Capital
khabdullah is on a distinguished road
I have simulated a tank subjected to harmonic excitation. I have used different turbulence model to simulate the same problem and validated the results with experimental data. The literature shows that SST k-omega gives false results when y+ increases beyond 8. But in my case y+ ranges from 0 to 100. A used Kato-limiters, intermittency transition flows and curvature correction in the model. The percentage difference in experimental and theoretical results is 2%.
I just want to make sure that the theory of k-omega also validate these results.
khabdullah is offline   Reply With Quote
Old   January 16, 2024, 01:52
Default A question
Zhaoqi Zheng
SJTUMEzzq is on a distinguished road
I am a beginner of FLOW 3D. I have a technical question. How did you apply the harmonic excitation in FLOW 3D. I want to simulate the sloshing behavior of cryogenic propellent in a tank. But I don't know how to apply an excitation. I would be very grateful if you tell me.
SJTUMEzzq is offline   Reply With Quote
Old   January 24, 2024, 11:00
Federal Capital
Hi, you can define the sinusoidal frame motion using UDF. You can get information about User Defined Function in Flow 3D user manuals.
internal baffle, k-omega sst model, sloshing, turbulence analysis, turbulence intermittency
[IHFOAM] The IHFOAM Thread Phicau OpenFOAM Community Contributions 392 September 8, 2023 18:10
At high Y+ values does the K Omega SST model just behave like the K Epsilon model? JuPa CFX 0 December 22, 2015 06:44
Weird results in MRF simulation of stirred tank with a steady state k-w SST model aminem OpenFOAM Running, Solving & CFD 2 January 3, 2015 11:21
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
A 1/4 Tank Model Omondi CFX 0 December 20, 2003 06:25
