If you want to add a mass source term, there is a derivative of the mass fraction in |
October 7, 2022, 02:47 |
xianyu hou
In the component transport problem, in addition to the convection term, the component conservation equation also contains a coefficient multiplied by the derivative of the mass fraction in the x direction. Can this item be regarded as a mass source term ? How to write this udf if you can ?
Is there any other way to deal with it ? This is a convection diffusion problem. The governing equations are mass conservation and momentum conservation. Thank you all |
October 7, 2022, 09:37 |
Lucky
Rep Power: 66 |
The coefficient multiplied by derivative is the diffusion term.
fluent udf source-terms |
Error message: Insufficient Catalogue Size | Paresh Jain | CFX | 32 | February 3, 2021 03:37 |
[swak4Foam] Installation Problem with OF 6 version | Aurel | OpenFOAM Community Contributions | 14 | November 18, 2020 16:18 |
momentum source for mass source term | Weiqiang Liu | FLUENT | 0 | July 25, 2019 11:20 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
