Negative drag on a 2D simulation
Old   October 11, 2022, 17:08
Default Negative drag on a 2D simulation
Lorenzo
lollouc19 is on a distinguished road
Hi everyone,
I am here to ask about a 2D simulation carried out on Ansys Workbench. The analysis consists of two Selig airfoils (in a downforce-generating configuration) with a certain gap and overlap between them; the bundary conditions are velocity-inlet for the inlet, pressure-outlet for the outlet, and then symmetry for the top and bottom walls.
Running the analysis on Fluent, I get negative drag for the first airfoil (-6N) and positive drag for the second (12N). Downforce is correct. How is this possible?
This happens using both k-epsilon and k-omega turbulence models.
Thanks for the help!
lollouc19 is offline   Reply With Quote
#negative #drag #fsae
How to not overwrite drag and lift coefficients after a simulation Giovanni Trovato FLUENT 1 August 1, 2018 00:31
Negative drag forces of fanwing airfoil vkid185 OpenFOAM Post-Processing 0 March 26, 2017 07:16
2D multi-element airfoil negative drag Etienne145 Main CFD Forum 3 November 9, 2015 03:31
Induced drag, pressure drag, viscous drag. aleix.de.toro FLUENT 2 August 24, 2015 18:00
negative airfoil drag?? Robin FLUENT 4 January 7, 2010 16:29
