What does specific URF do to the simulation
Old   October 11, 2022, 03:37
Question What does specific URF do to the simulation
Michał Basisty
omichalo121 is on a distinguished road
Okay, i'm still working on a combustion furnace, so I can get the ideal temperature in thermocouples compared to the real ones. My supervisor recently changed temperature and energy URF from 1 to 0.5 and suddenly the temperature skyrocketed with very little change in fuel inlet.
Now the question, how does the temperature/energy URF influence the temperature in the furnace? From the plane view of Static Temperature it seems like there's little of energy coming out of the furnace, the whole volume is almost the same (in meaning of temperature contour).
Any help would be appreciated!
omichalo121 is offline   Reply With Quote
Old   October 13, 2022, 06:15
Luca
xisluke is on a distinguished road
URFs shouldn't affect the solution (at least from a physical point of view). In few words, URFs aim at optimize the convergence process of your analysis by reducing oscillations within the iterative procedure. Basically, once the solution is solved, it is "blended" with the previous solution, in order to prevent from excessive variations in the result (explicit under relaxation). Another way is to apply relaxation directly within the matrix (implicit relaxation). Conceptually:
URF < 1 ---> Under-Relaxation
URF = 1 ---> No relaxation
The more you apply under-relaxation, the more your convergence will be slow and (theoretically) less prone to oscillation. Obviously, stability problems do not depend on URFs only. Usually the goal is to identify the best trade-off between stability and speed of the analysis.
xisluke is offline   Reply With Quote
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 21:43
Transient simulation gives worse results than steady state simulation jgross CFX 12 January 21, 2021 12:21
How can I get the simulation data of a specific model area? UdoUebel STAR-CCM+ 2 January 29, 2016 05:00
Pressure time history at specific points on a surface during unsteady simulation drrbradford Fidelity CFD 0 July 15, 2010 10:13
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
